Hi, I need to build a PSU for a sputtering deposition chamber. The requirements that I was given are:
4 kV DC 250 mA for 5 min, turned on and off manually, powered from mains
I have a microwave transformer (220 V - 2.2 kV, 1450 W) which would give about 3.1 kV DC after full wave rectifying and filtering (diode bridge+cap) and more than enough current. I was thinking about a few options:
1.- Making a sine wave PSU capable of delivering 400 V peak (sinusoidal oscillator at a low voltage, around 12 V peak for example, connected to a 220/6 V transformer, then to the HV one).
2.- Same as option 1, but using a square wave from a 555 instead of sinusoidal. I don't know if it's okay to apply a square to an iron cored transformer (after removing the DC component) because of the distortion introduced by its attenuation to high frequencies.
As a side question, if I needed to make it regulated, how would I be measuring the voltage if I wanted to do it in the HV side? Simply a voltage divider, a voltage follower op amp and an optocoupler? (I know that I can measure from the intermediate stages, ie the 400 V one or even 12 V one).
Thanks in advance for any help that you can give me.
PS: I only need a single unit.
