Author Topic: high voltage opamp?  (Read 7017 times)
Offline sgt_bearTopic starter
high voltage opamp?
« on: December 08, 2017, 07:14:04 pm »
Hello
I have to measure a current in a high voltage system (150-250V DC). The measurement has to be made on the high side via a shut.  The shunt can be relatively large, anything <1kOhm will do.
Usually at low voltages, a differntial opamp would do.  All approved solutions are found are for high currents in high voltage, but i need very low current measurements. The possible currents are 0-20mA and i would like to have a 100uA accuracy.
What would be the best way to solve this problem?
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
He’s like a trained ape. Without the training.
Offline jeroen79
Re: high voltage opamp?
« Reply #2 on: December 08, 2017, 07:37:57 pm »
Battery powered ADC on the high side that transmits the measurement optically to the rest of your equipment on the low side.
Offline f5r5e5d
« Reply #3 on: December 08, 2017, 07:52:41 pm »
The following users thanked this post: BrianHG
Offline ebclr
« Reply #4 on: December 08, 2017, 08:03:05 pm »
« Reply #5 on: December 08, 2017, 08:37:04 pm »
Yes, but HOW does the ADC can measure the current safely
Basically all i need is  the same function which a multimeter has, you just place the multimeter as shunt, and the current measurement will work. How do multimeters measure the current
Offline Paul Moir
« Reply #6 on: December 08, 2017, 08:46:47 pm »
They float, which is to say they have no earth ground reference.  That's why they're battery powered and if they do have communications it's usually done optically.
If you need isolation from this `150-250V, it's going to boil down to a "DC current clamp in a chip" like solution (eg LEM current sensors) or "Floating multimeter with an isolation barrier" like solutions (jereon79, frozenfrogz, etc).
Offline daqq
  • Country: sk
    • My site
« Reply #7 on: December 08, 2017, 09:08:06 pm »
They measure voltage on a resistor through which current is passing. The simplest solution these days would probably be to make a floating ADC with some support circuitry. You isolate the digital and power interface from the grounded side via isolators.
Some inspiration: http://www.linear.com/product/LTM2893
Mind you, this can be done with far less exotic parts :)
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #8 on: December 08, 2017, 09:17:13 pm »
Any of those current output type current sense amps can be used, given that you can spare the quiescent current, and that you cascode the output with a high voltage transistor to shift the signal down to ground level.
Seven Transistor Labs, LLC
Offline David Hess
  • DavidH
« Reply #9 on: December 08, 2017, 09:41:24 pm »
If isolation is not required, then I would use the configuration shown in figure 1 here:
http://www.analog.com/en/analog-dialogue/articles/high-side-current-sensing-wide-dynamic-range.html
The only high voltage parts are the Rbias resistor and the output transistor.  Use a low power operational amplifier to minimize the current through Rbias.  For a wide voltage range, replace Rbias with a constant current sink.  The amplifier requires an input common mode range which extends to its positive supply.  In the past, an LM301A might have been used but a TL031 has a lower supply current and would be my first choice now.
Online Zero999
  • 0999
« Reply #10 on: December 08, 2017, 11:48:02 pm »
You mean this circuit? Yes, I agree.
There seems to be a reasonably wide selection of suitable MOSFETs available. I've had a quick flick through Mouser and the ZVP0545A and ZVP4525G seem to be the most cost effective.
http://www.mouser.com/ds/2/115/ZVP4525G-94131.pdf
http://www.mouser.com/ds/2/115/ZVP0545A-92870.pdf
« Reply #11 on: December 09, 2017, 05:56:37 pm »
The AD8628 is 5V supply?
I guess if i connect the AD8628 as shown in the schematic to BUS VOLTAGE (which is 250V DC) in my case, i'm sure it will DIE very fast!
« Reply #12 on: December 09, 2017, 06:00:03 pm »
I was planning to use the
LT6375 +-270V Common Mode Amplifier, but sadly the part is designed for higher currents. if used with low currents the precision gets wasted because it only has very low REF Resistors which consume current themself...
http://cds.linear.com/docs/en/datasheet/6375fa.pdf
Basically i'm looking for the same solution as shown on page 1, but with a lower current leak through the amplifier... :(
Online T3sl4co1l
« Reply #13 on: December 09, 2017, 06:02:19 pm »
Supply is zener diode regulated.
Online Kleinstein
« Reply #14 on: December 09, 2017, 06:08:44 pm »
The OP for the current sense part has a zener to provide a regulated Supply of about 5 V. So the OP will be OK.
The only part that needs to be high voltage are R_Bias and the P-channel MOSFET. If the requirements are not high a PNP transistor would work too and might have an advantage if the drop at the shunt is larger than about 2 V.
It the bus voltage changes a lot, one might want to change R_bias to a current source (e.g. a depletion mode MOSFET + resistor).
There are lower power OPs than the AD8628. One might not not need an AZ OP - it could as cheap as an MCP6001.
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #15 on: December 09, 2017, 06:12:11 pm »
You can try making a small battery operated current sense module and let it pump data down an optical or RF link. You can run RS232 over TOSLINK POF or run BASE-X Ethernet with a SFP module if you want to go optical. If you want to go RF just get ESP8266 and drop it into your local Wi-Fi network.
EDIT: Speaking of POF, you cal also use analog POF with an analog battery-operated circuit on the high side converting the current into light intensity in the POF, and pick it up using a photodiode on the low side.
« Last Edit: December 09, 2017, 06:15:21 pm by technix »
« Reply #16 on: December 09, 2017, 06:21:10 pm »
Hm... am i not understanding opams here right? If i put the in - and + to high voltage, will the opamp survive ? On the shown circuit my 250V would directly go into IN -  ?
Offline David Hess
  • DavidH
« Reply #17 on: December 09, 2017, 06:41:02 pm »
The operational amplifier only sees the voltages between its various terminals.  The positive supply terminal follows the +250 volt input.  The negative supply terminal follows the +250 volt input minus the zener diode voltage which could be anywhere from 5 to 30 volts depending on what zener diode is selected.  The current drawn by the Rbias resistor is the sum of the current from the operational amplifer's negative supply terminal and the current through the zener diode.  The bias current should always be higher than the maximum supply current for the operational amplifier.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #18 on: December 09, 2017, 06:44:56 pm »
Think this way: you got a floating ground for the op amp, and you need to shift the ground reference down. The RF and optical methods I suggested simply breaks the ground, and that schematic shows a way to level shift the ground down.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #19 on: December 09, 2017, 06:49:22 pm »
Another breaking the ground idea: there are isolated power supply modules out there, and you can use chips like ADuM1401 or ISO7241 to get an isolated SPI bus. You can power the op amp and the ADC using that isolated power supply as well as the slave end of the signal isolator, and pull data from the low-voltage host end.
Online T3sl4co1l
« Reply #20 on: December 09, 2017, 09:23:58 pm »
Related:
https://www.eevblog.com/forum/beginners/high-voltage-high-side-current-amplifier/
The circuit shows precisely what I mentioned in #9. :)
« Reply #21 on: December 11, 2017, 12:10:48 pm »
But if the OP AMP runs on 5V, why do i have to take the 5V from the BUS? Can't i supply just regular 5V there?
Offline RES
« Reply #22 on: December 11, 2017, 12:46:55 pm »
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #23 on: December 11, 2017, 03:21:56 pm »
You need to be aware of the reference point from which the measurement of 5V is taken. Voltage is relative. This is why I have been babbling about a little concept called floating ground as the reference ground of the "5V" the op amp is operating from and the reference ground of the rest of the system is very different.
« Reply #24 on: December 11, 2017, 08:10:03 pm »
