Author Topic: Home made feed through terminator for BNC  (Read 885950 times)
Offline Icchan
Re: Home made feed through terminator for BNC
« Reply #25 on: July 20, 2017, 08:00:44 pm »
I'd like to try and build one of these for fun and usefulness, and give a few out to our local Hacker-space as well, for use in what ever they deem necessary.
I tried to find suitable parts from eBay/the usual places, but to no avail. Could someone help me out a bit?  :)
« Last Edit: July 22, 2017, 01:40:10 am by Icchan »
Offline bjcuizon
  • RF and Analog Electronics Enthusiast
« Reply #26 on: July 20, 2017, 08:14:18 pm »
I'd like to try and build one f these for fun and usefulness, and give a few to out local Hacker-space as well for use in what ever they deem necessary.
How about trying RS Components. I bought some parts there for this diy terminator. The male bnc is just a standard coax solder type bnc and the female one was a panel mount type. For the resistors, I just used a couple of 100R smd ones. Just be careful while selecting the resistor. The size gets bigger as the wattage gets higher (of course), and it may not fit inside the bnc plug assembly.
Parts List (I used):
2512 Thickfilm Chip resistor 100R; RS Stock No.739-7957
Clamp BNC straight plg-RG58A cable,50ohm; RS Stock No.546-4875
NiPt soldered std BNC bulkhead skt,50ohm; RS Stock No.546-4897
DISCLAMER: I am not affiliated with Radio Spares Components in any way. I'm just a satisfied customer.
« Last Edit: August 29, 2017, 08:32:00 am by bjcuizon »
Don't mess with an Electronics Engineer, it Megahertz!
Offline xzswq21
« Reply #27 on: October 20, 2017, 05:02:06 pm »
Dear
the input impedance of my oscop is 1M || 15 pF.
can I make the input impedance of the oscop to 50 Ohm using Pomona 4119-50?
if so can I make it a feedthrough adapter like you?
if the output impedance of a signal generator is 50 Ohm is it necessary to use of such 50 Ohm feedthrough terminations?
Please reply me as fast as you can :)
Regards
« Last Edit: October 20, 2017, 05:07:20 pm by xzswq21 »
Offline bjcuizon
« Reply #28 on: October 20, 2017, 10:17:52 pm »
Dear
Regards
Yes, you need to terminate your fun gen into 50 ohms if its got a 50 ohm output impedance. You can use the termination you mentioned above or build one for cheap yourself. Just look at the other finished products above and how the other users have constructed it.
Offline xzswq21
« Reply #29 on: November 12, 2017, 08:30:00 am »
I'm gonna buy two 50 Ohm Feed through.
Do you know any products from mini-circuits company?
Thanks
Online tggzzz
« Reply #30 on: November 12, 2017, 10:54:52 am »
Yes; there are many.
All you have to do is look at their website.
The following users thanked this post: xzswq21
Offline xzswq21
« Reply #31 on: November 12, 2017, 01:59:29 pm »
Dear
I've looked at many products! but I didn't see any feed through. there are many attenuators and filters but I couldn't find any feed through.
Thanks
Offline EJP
    • Dada Electronics Australia
« Reply #32 on: March 05, 2018, 02:50:24 am »
Jaycar part numbers for David's method:
PS0658 BNC PANEL Socket - SINGLE HOLE MOUNT
PP0650 BNC Male Line Plug
EJP
Offline EJP
« Reply #33 on: April 18, 2019, 07:52:00 am »
Have a look at Broadave Technologies: https://www.broadwavetechnologies.com/.
Offline MichMich
« Reply #34 on: May 23, 2019, 12:54:40 am »
Has anyone ever tried to built/modify/repair an SMA fee-thru termination? Are the resistors the same as those for the BNC ones?
Some examples of sma feed-thru terminations:
1) https://www.broadwavetechnologies.com/product/feed-thru-termination-50-ohm-dc-1-ghz-2-watts-sma/
2) https://www.pasternack.com/2-watts-sma-male-feed-thru-load-up-to-1-ghz-pe6026-p.aspx
« Last Edit: May 23, 2019, 01:02:45 am by MichMich »
