Electronic is just my hobby and not my profession. I started years ago with digital technic and since about four month I engaged in the analog technic stuff. I decide to design a network analyzer to learn more about filter, amplifier, mixer, oscillator etc. In my point of view, it is a good idea to have an objective. Because defining a way to learn stuff is much easier if you know, or have an idea, about the result and what is it good for.
Yes, I know there are a many NWA’s on market – used, new etc. But some time the way is more important than the objective.
First of all I will define the major requirements or my major needs to margin work and efforts.
The network analyzer should be:
- based on modules (easy exchange of function blocks),
- inexpensive (use of standard parts, if possible one or two sources for parts to reduce additional cost. E.g. shipment),
- PC controlled via USB, Bluetooth or RS-232 (no external controls like switches, displays etc.),
- have a frequency range from about 10Hz to max. 50MHz.
I will use the NWA for (see attachment to this post)
- measure signal level changes,
- phase changes and
- reflection/impedance of the DUT.
I will post my ideas, current status, results, questions and more from time to time in this section.
