The circuits are quite simple. Usually around a 60-90V supply is used with just a FET with
resistor limiting the current. Resistors can be switched in, but usually a 1,2,4,8 binary
with a FET for each resistor. The range of 1-10K generated by a SG3524 or similar switching
regulator to give frequency and duty cycle. A 150V low current pulsed same as the main high
current supply is sometimes used to help initiate the arc.Sinker machines use a kerosene
like oil for the dielectric and wire machines use water. High duty cycles and low frequencies
give a rougher finish. Distance control is critical. In sinker machines hydraulics work best
for precise movement. All rather simple till you want to do real precision. Then it is experience
and art in selecting electrode material, speed, currents,frequency and duty cycle. There
ought to be circuits online. Used machines for cheap are plentiful here. Mechanicals are the
toughest to build. Some good articles that can be sourced online of this magazines archive.
http://www.edmtodaymagazine.com
