just get a big 240V to 120V transformer. goto elec. shop and ask. i used to fool around with transformers (smaller one, but for bigger one i think theoritically the same, it just depend on the transformer power rating). at the very most, when u shorted the transformer output, it will get hot, red and eventually melted away. just dont fool around with the main side (input) of the transformer, u will have a big explosion, even bigger if u dont have circuit breaker protection in your house. if u use underrated transformer, it will heavily loaded and get hot and fail fairly quickly, but if you use larger one, no problem at all. even at the same rated transformer and equipment, transformer will get hot. i used to put fan to cool it down and live longer, thats how high end adapters are doing. if u want to output DC, then you'll have to have support circuitry, rectifier and stabilizer caps. but as the thread owner just simply want to use 130V appliance on 240V main, then a single big 1:2 stepdown transformer will do the trick. for AC motor, pls dont rectify the AC supply, AC motor needs AC supply. same thing with DC motor needs constant voltage supply to work perfectly, its just their design and architecture in amarture and winding that requires those kind of supply. just my 2 cents opinion.
