Author Topic: how to avoid ground loops in battery powered projects?  (Read 2280 times)
Offline Sv443Topic starter
« on: January 14, 2018, 02:46:29 pm »
Hi, I'm making a bluetooth speaker right now but no matter what I do, I keep running into a really annoying problem. I am using a TP5000 3A li-ion protection board. The 4V output gets amplified to 12V to drive the speaker and to 5V to power the KRC-86b bluetooth module. But if I do that I get really annoying distortion and background noise. I have heard that sensible electronics and audio-electronics sometimes run into this problem too and I wanted to know how professional manufacturers solve this and how I can solve this issue.
Please keep your answers simple, I'm not the best electrician.
Thanks!  ;D
Offline madires
  • A qualified hobbyist ;)
Re: how to avoid ground loops in battery powered projects?
« Reply #1 on: January 14, 2018, 02:55:02 pm »
Could be the boost converters. Do you got a lab PSU to power the amp and the Bluetooth module directly for testing?
« Reply #2 on: January 14, 2018, 06:33:00 pm »
Yes I already tested it with an external PSU and it solved the problems. And I also think its the boost converters but without them I don't know how to do it.
Offline David Hess
  • DavidH
« Reply #3 on: January 15, 2018, 02:14:02 am »
Single point grounding to prevent ground loops and RLC decoupling between modules is usually enough to prevent problems.  In extreme cases with audio circuits, I have used currents instead of voltages or instrumentation/difference amplifiers to remove ground noise.
Offline madires
« Reply #4 on: January 15, 2018, 11:14:18 am »
You could try adding LC filters to the outputs of both boost converters, maybe 10 or 22µH and 470µF as a starting point.
Offline ovnr
  • Country: no
  • Lurker
« Reply #5 on: January 15, 2018, 11:28:33 am »
Have you checked which power rail is the biggest problem? Consider adding linear post-regulators to the boost converters.
If you're adding LC filters like madires suggests, make sure that you're making a properly damped system. A low-ESR inductor paired with a low-ESR capacitor will ring at certain frequencies. Using a higher ESR inductor - or even adding some series resistance - plus a good old aluminium electrolytic will make it easier to avoid any such issues.
