Higher current density is allowable because the transformer is physically smaller.
Higher by 2-4 times, depending.
However, you may find that, for very high currents, unusually heavy wire has to be used, or divided up, possibly into many fine strands (Litz cable). This occurs because the current is not flowing in the entire cross section of the wire, at high frequency and deep within a winding.
