The simplest method that i can think of is to use a temperature controlled soldering iron to find the softening/melting point of the insulation tht should narrow It down, pvdf is also quite chemically stabile, so there might be some chemically that attacks most plastica but leaves intact pvdf( you should ask someone with more of a chemistry background than me if you want ti take the route TBH)
