mechanical relay works on almost any voltages, but if mechanical is not your taste, you can cheat by supplying the IC with dual rail supply, ie IC's gnd = -ve voltage. not looking at the IC's datasheet, but if the IC doesnt have drain capability then you may need to homebrew, simply like pull down resistor to -ve rail, ymmv.
