I only read a couple of pages of this thread, and I have to admit that it was all 'intriguing' to say the least...
Many of the comments dealt with various methods to keep the fuse from getting hot enough to actually melt.
Immersion in liquid nitrogen was one, fairly logical, method to keep things nice and cool....
However...
Is there any aspect of the rules that state you're not allowed to 'immerse' the entire fuse (holder and all) into a nice bath of ... say... good old LEAD.
Imagine a small pot / kettle full of molten lead. The race inspector first 'verifies' that you have the 'correct' fuse and possibly even the correct fuse holder too. Once it has 'passed' that inspection, you immerse the ENTIRE fuse + holder into the bath of molten lead (making sure the molten lead forms a nice connection to BOTH sides of the fuse). You wouldn't even need to retain the lead in a molten state... (In fact, it'd possibly be wise to HELP it solidify)
It'd probably qualify for the "I am not mad but..." clause, and I'm pretty confident that with a large enough 'bath' of lead that just happens to be in direct contact with BOTH of the fuse connections, the fuse would be fairly unlikely to blow... Hell, even if it DID manage to melt the fuse, the surrounding 'lead bath' would still happily allow a few THOUSAND Amps!!! <Grins>
(I'd strongly recommend installing an 'additional' fuse of appropriate rating for basic safety though).
Then there's the next suggestion....
Does it actually SAY in the rules that you cannot connect both the SUPPLY feed _AND_ the load from the motor onto the SAME side of the fuse? (i.e. The fuse is actually NOT pat of the circuit)
In that case, I would SERIOUSLY doubt the fuse would blow even if you were drawing several MEGA AMPS. (If the fuse DOES somehow manage to go open circuit though, you'd have some SERIOUS issues and might require the fire department rather urgently)
