The output of a transformer is AC.
With low power transformers (let's say 10-50VA), the output of the transformer can often be a bit higher than the value listed on the transformer if whatever is connected to it doesn't use all those 10-50VA. It could be up to 10-15% extra. When the device uses all those VA, the transformer's output will be closer to the label.
You need to convert the AC to DC and this gets done using a bridge rectifier. The output of the bridge rectifier will be a DC voltage that varies between 0v and a peak voltage of Vac x 1.414 but since there are always two diodes conducting in the bridge rectifier at any time, you have to take out two times the voltage drop on a particular diode in the bridge rectifier.
The voltage drop on each diode in the rectifier varies with the amount of current and the temperature of the bridge rectifier. For example, a bridge rectifier rated for a maximum of 2A may have diodes with a voltage drop of 0.6v at 100mA but these will go up to let's say 0.9v at 1A. So when you select the parts, you should be
Vdc peak = 1.414 x Vac - 2 x Vdiode
Now remember, since we still have fluctuations in this DC voltage, we need to smooth out this DC output and for that you use capacitors. There's a very simple formula that approximates how much capacitance you would need to keep the DC voltage always above a particular level:
Capacitance = Current / ( 2 x AC Frequency x Vdrop)
where V drop is how much you're willing to let the DC voltage go down from the peak DC voltage.
For example, let's say the peak DC voltage out of the bridge rectifier is 17v and you want to produce a 12v at maximum 1A using a linear regulator, let's say a 7812 which requires about 1.5v above the output to work properly. So that means the DC voltage it receives at the input should always be between 13.5v and 17v.
So now we can use the formula to get the minimum capacitance required to always have 13.5v even when the regulator does 1A of current:
Capacitace = 1 Amp / ( 2 x 50 Hz x (17v peak dc voltage - 13.5v minimum voltage) = 1 / ( 100 x 3.5) = 1 / 350 = 0.002857142 Farads or about 2857uF.
I'm assuming 50Hz because that's the AC frequency in Europe and some other countries. In US it's 60 Hz.
So 2857uF is not a standard value, but we can choose the next value up, 3300uF.
Of course, you can use much larger capacitance but that will only keep the minimum dc voltage closer to 17v which is pointless in this situation because the linear regulator will dissipate the difference between 12v and 17v as heat anyway.
Note though... you have to keep in mind that your mains AC voltage is not always super stable... You don't always have 230v or 110v, and you have to also consider who's going to use your device. Depending on the input voltage fluctuations, the AC voltage on the transformer could also vary, so you have to be careful when designing such a classic power supply and don't assume the transformer will always output a minimum voltage written on the label.
