I have a proof of concept board that triggers twelve
LEDs (four parallel strings of three) matched to ~3ns with total propagation delay of ~15ns. They are triggered at 1MHz for up to 33% duty cycle.
I need to trigger 225 LEDs (45 parallel strings of five) matched to <5ns with a total propagation delay of <30ns.
Currently the trigger comes into the board and goes
1. to a transceiver (SN74AVC1T45) that level shifts to 3.3V, then
2. to a quad XOR (74LVC86A) that splits the signal, then
3. to four low side gate drivers (UCC27524) that switches the four strings of LEDs directly.
Scaling this up while keeping 225 LEDs matched to within 5ns is my biggest concern. What would be the best way to keep such tight timing?
1. Split the signal a couple more times and use 45 drivers, one for each string? The current XOR only imparts about 5ns delay so a couple more layers might be tolerable.
2. Add a few large power FETs after the drivers. Each FET could switch the ground for multiple parallel strings.
3. Something else?
