The seed dimension, weight, size are very unpredictable, also because of this unknown there is no way to calculate an accurate math I think.
But, here is what I setup days ago and how I played with this stuff and the result on my scope:
My setup is on my breadboard.
I used 1 photo sensitive diode and 1 IR LED diode all they 5mm diameter.
They are 6 cm far from each other.
The actually distance on a seeder machine is below 4cm.
So, my setup is a bit over distanced.
The photo sensitive diode is connected to the 1A on a 74HC14 Schmitt trigger.
And the CH1 of my scope also connected to the 1A of the IC.
The CH2 is connected to the 1Y of the IC.
When I drop a corn seed to interrupt the light I measure the result with my scope:
As you can see, the CH1 is the analog part of the signal and the CH2 is the output of the Schmitt trigger on 1Y.
The seed is traveling around 5.8mS until it left the sensing region.
I tried hundreds of time with a couple of hundred of different corn seeds and the time was between 3ms up to 7-8ms.
Depending on the seed weight and dimension I assume.
This signal looks me fine to use and is very stable until the test on my bench.
I don't had the ability to try it in real life on seeder machine for now.
Why can we not use this signal in some way together with each other rather than using the uA etc.
region what are really nasty to setup and control that small amount of current.
Maybe that could change his behavior on a more hot day, or more colder day, or more moisture or whatever.
And this is a signal when I press a button on my DVB remote control.
The same distance of 6cm from the photo sensitive diode is my DVB remote control.
Sorry for this kind of interrupting but this signal looks really good for me.
What you are think about this?
Don't pay attention to the ripples on CH1, that comes from my breadboard....
