Author Topic: How to wire up a 6ch delay timer for dolls house  (Read 5184 times)
Offline Andy698Topic starter
« on: August 16, 2017, 04:53:09 pm »
have no i131574529512dea about electronics. I purchased the item to control lights (off/on delay) the 6 ch will control 32 lights (6 div 32=5 light clusters).
What I need to no.
Power pack size (v)
How to wire the lights
How to wire the power pack.
The unit is about the size of fifty pence.
You can find this items description on eBay item no 131574529512
The following information was provided by the manufacturer!
100% Brand New and High Quality
This is a mini size but very useful delay timer module. It has 6 independent channels for delay output.Multi-Channel Easy Use Delay Timer Module (with Status LED for each channel) Each channel time adjustable by potentiometer
Output terminal of the module has protection diode. The module can directly drive relays and other similar inductive loads.
Question: For what application can this module be used for:
Answer: This module has 6 channels of time that can be adjusted independently (the delay time depends on input voltage, which will be specified below). It is suitable for turning on a series of circuits or devices by a set sequence.
Product Details:
Power Supply: DC 3V - 18V
Static electricity: less than 0.1 uA
Output drive capacity: 300mA * 6 channels
Drive Mode at the Drive Side: NPN triode
PCB Size of the Module : 20 * 32 mm
Delay Time Details:
6-channel delay time can be adjusted, the time adjustment range and power supply voltage, so it is best to use power supply.
The following are common voltages measured values:
3V :  0 - 9 seconds adjustable
5V :  0 - 8 seconds adjustable
12V: 0 -  4.5 seconds adjustable
18V: 0 - 3.5 seconds adjustable
Can use some modules together in series to increase output terminals.
Example Applications:
1. Use one module:
K2 disconnected, K1 closed, L1-L6 lights up one after one, and at last L1-L6 stay on lit-up status.
If K1 disconnected, L1-L6 all go off.
If K2 closed, no matter K1 at what status, L1-L6 will not light up.
[ Attachment Invalid Or Does Not Exist ] 107559[/ATTACH]
2. Use multiple modules in series:
K2 disconnected, K1 closed, L1-L11 light up one after one, and at last all stay at lit-up status.
If K1 disconnect, L1-L11 all go off.
If K2 closed, no matter what status K1 is, L1-L11 will not light up.
Offline bingo600
Re: How to wire up a 6ch delay timer for dolls house
« Reply #1 on: August 17, 2017, 09:40:46 pm »
What type of lamps will it drive ?
You do know it can only delay at max 0..9 seconds (driving a 3v led)
/Bingo
« Reply #2 on: August 18, 2017, 06:57:32 am »
The bulbs have yet to be installed. I assumed higher than 3v would produce longer delays is that not the case?
Offline Ian.M
« Reply #3 on: August 18, 2017, 07:01:45 am »
No. the delay DECREASES with increasing voltage.
You'll probably want to use 'grain of wheat' bulbs or small LEDs so they aren't too far out of scale for the model.
« Reply #4 on: August 18, 2017, 09:00:17 am »
Im going to test the circuit to see how it performs  using  Mobile phone charger so we're do the two
wires (+ -) go from the charger to circuit including the two wires from the bulb?
Offline Ian.M
« Reply #5 on: August 18, 2017, 09:50:14 am »
*CAUTION*
Incandescent bulbs typically have a cold resistance ten times less than their hot resistance so they draw a lot more current at the moment of switch-on.
As your timer is only rated for 300mA load current per output, using it with any bulb that draws more than 30mA when lit will overload it at switch-on.
If the bulb current isn't specified, you can calculate it from its  rated voltage and wattage
Most modern phone chargers are 5V so you'll probably need 5V bulbs of no more than 30mA or 0.15W rating.
Follow the wiring diagram from the EBAY ad for the module.  N.B Vcc is the common name for the  positive power feed to a chip, board or module that uses bipolar technology (and Vdd for CMOS devices)
« Last Edit: August 18, 2017, 09:53:30 am by Ian.M »
« Reply #6 on: August 19, 2017, 02:15:54 pm »
This is the second electronic forum iv been to ask a simple question how to wire a fone charger and a xmas light bulb to a 6 ch delay circuit?
They all tell you what it is but not how to wire it?
Offline Ian.M
« Reply #7 on: August 19, 2017, 02:31:10 pm »
What problem do you have with following the wiring diagram given in EBAY ad 131574529512? (copy of diagram attached below)
N.B. an xmas light bulb may overload and damage your Delay Timer Module, or may be the wrong voltage to run off a phone charger.
« Last Edit: August 19, 2017, 02:34:36 pm by Ian.M »
« Reply #8 on: August 19, 2017, 03:17:46 pm »
Just we're the wires go when connecting to circuit board ?
The two wires from charger?
The two wires from light bulb?
That's all I need to no the rest I will deal wiv thankyou?
Offline Ian.M
« Reply #9 on: August 19, 2017, 03:36:27 pm »
Charger + wire to Vcc, - wire to Gnd, and bulb(s) wired as per diagram
« Reply #10 on: August 19, 2017, 03:48:36 pm »
I'm not electronic eng. so I can only see we're one wire gos for bulb that's on one of the 6 ch prongs of circuit now were does the other go?
Offline Ian.M
« Reply #11 on: August 19, 2017, 03:55:22 pm »
It joins onto the wire along the bottom of the diagram which goes to VCC.  |O
« Last Edit: August 19, 2017, 03:58:05 pm by Ian.M »
« Reply #12 on: August 19, 2017, 03:58:31 pm »
Which pins that?
« Reply #13 on: August 19, 2017, 04:04:47 pm »
This is hard wired there is no other plug in or circuit boards
Offline Ian.M
« Reply #14 on: August 19, 2017, 04:14:33 pm »
The Ebay ad's second photo shows the pin names marked on the back of the board.   If your board is missing the pin names follow the photo, but ONLY IF your board is otherwise the same as the one shown in the photos.
Did anyone mention 'plug in' or other circuit boards?
If you need further help, we would need to see a photo (well lit, in focus and high enough resolution to read any component markings) of the parts you have so we can literally draw wires on it for you.
To prove you aren't trolling us, please put *ALL* the parts in the same photo and use the front page of a recent newspaper as the background, with the 'masthead' and date clearly visible.  I apologise in advance for being suspicious! 8)  :popcorn:
« Last Edit: August 19, 2017, 04:16:36 pm by Ian.M »
Offline Zero999
  • 0999
« Reply #15 on: August 19, 2017, 04:45:54 pm »
As mentioned above, the piin names are on the reverse of the board.
Unfortunately it may be hard for someone to solder wires directly to the module, if they've never soldered before. I recommend soldering it to a piece of strip board (Google is your friend, if you don't know what this is) and soldering the wires to that.
« Reply #16 on: August 19, 2017, 04:56:27 pm »
I'm getting utterly confused here? One wireframe the bulb gos to pin 3 lets say! Now we're does the other go ? Are you saying it's soldered on the actual circuit next to the pin 3?
Offline Zero999
  • 0999
« Reply #17 on: August 19, 2017, 05:22:37 pm »
The other side of the bulbs all go to the positive supply.
Connecting the bulbs is easy. It's the switches which I'd be unsure of, because the labels on the schematic don't match the silkscreen on the PCB.
« Last Edit: August 19, 2017, 06:08:30 pm by Hero999 »
Offline Ian.M
« Reply #18 on: August 19, 2017, 06:05:52 pm »
I'd *guess* that 'ON/IN' on the board is 'START' on the diagram and 'OFF' on the board is 'STOP/IN' on the diagram, but as the bastards that build this cheap sh!t sand the numbers off the chips, there's no way of checking except to hook it up and see whether it works or it lets the magic smoke out.
Offline Zero999
  • 0999
« Reply #19 on: August 19, 2017, 06:14:25 pm »
I agree, it's a pile of poo. The fact that the delay varies with the supply voltage is also a sign of poor design. If it were designed properly, they delay would be fairly independent of the supply voltage. If more adjustment is necessary, there should be another potentiometer to alter the delay on all channels.
My guess is the ICs are something generic, but if the OP can't even figure out how to wire up the lamps, there's no chance they'll be able to reverse engineer it.
« Reply #20 on: August 19, 2017, 06:40:52 pm »
My god after several messages ?
I get a drawing we're the wires go?
Thankyou very much for your help
Offline Zero999
  • 0999
« Reply #21 on: August 19, 2017, 07:59:32 pm »
Now, please do yourself a favour. Compare the picture I've drawn, against the electrical schematic and figure out how I did it. This isn't rocket science. You don't have to be an electrical engineer to do this. I could have done this before the age of 8.
« Reply #22 on: August 19, 2017, 08:53:26 pm »
I thankyou I am dyslexic according to Mensa it's 109. I asked a simple question how to connect four wires ? What I got was a problem? Yes you told me what it is because I gave you the pins and instructions? All you have done is repeat what I gave you?
Now let's have a think about this.
4 wires 2 from phone charger
and 2 from the bulb?
And you won't me to send a picture with today's paper ?
Nutts ?
Offline Zero999
  • 0999
« Reply #23 on: August 19, 2017, 09:07:42 pm »
Nutts ?
Yes, clearly I'm nuts.  :palm: |O |O |O
Offline Ian.M
« Reply #24 on: August 19, 2017, 09:25:50 pm »
At this point I don't really care if the O.P. is trolling, as the entertainment level is already close to that of daytime TV!  :popcorn:
I'm just waiting for season 2 when it does sweet F.A. because it needs a switch, and season 3:
which will let the magic smoke out unless the  'xmas light bulbs' used are LEDs with integral resistors and each draw well under 50mA @5V.
Of course the odds are currently 50:50 that  the magic smoke gets let out in season 1 due to inability to determine which phone charger wire is positive, and the whole show gets cancelled . . .  >:D
