You can use a piezo lighter for -4-2 precomp testing, but it is in no way a substitute for the correct series of tests, especially the ones with coupling planes, or air discharge.
EFT is a rapid sequence of ESD-like pulses transmitted down a cable. You could perhaps calibrate a relay contact inductive switching circuit to approximate it, that being the primary origin of that hazard in-the-wild.
Surge isn't easy to do without some big thyristors. The network isn't hard, but charging, switching and coupling it, is.
Also, OP has probably solved their scheduling issue, one way or another, in the past 6 months...
