I recently got this module:
http://blog.zakkemble.co.uk/wp-content/uploads/2012/12/modules.jpghttp://www.electrodragon.com/w/NRF905_Transceiver_433MHz-Wireless_ModuleI want to use it to transmit data between my flat and my garage, which
is 7 floors below. Thus, this is a vertical configuration. For testing
purpose, I tried this:
. a module sends packets from the garage. The power gain is set to max
(10 db, adjustable in software). The packet size is limited to 6 bytes
CRC and automatic retransmission are disabled.
. a receiving module is located in the flat. 3 different messages are
printed if the carrier is detected, data are received, and all the data
bytes are correct.
In my flat, the carrier is not detected. 2 floors below, the carrier is
detected. 3 floors below, data are received and all correct. Thus,
communication between the flat and the garage seems possible to me, but
the range needs to be improved a bit. To do so, I plan to try different
antenna designs. For instance, I found this doc, where page 14 describes
the bulding of a ground plane antenna:
http://www.arrl.org/files/file/Get%20Licensed/Quickstart%20Guide%20EBOOK.pdfDo you have any advice about antenna designs that are well suited for
this kind of vertical transmission configuration ? What are the other
points I could improve ?
Thank you for helping!
