If you are helping to solve the engine mystery than you should have something to bring to the table..................
I mentioned in an earlier post that I have been suggesting that solid core plug wires should be fitted to replace the common type suppression leads on the car (core type unknown), for some weeks now. There has been resistance and all of it is not in the car! (pun intended).
Somewhat reluctantly, the owners have ordered a set of solid cored ones as described above.
Also, I now have arranged the loan of an oscilloscope and suitable probes with which to do an ignition analysis should the new leads not solve the problem.
I don't have anything else to "bring to the table".
Meanwhile, the owners brother is talking about the problem still being induction related. Even though two very different carburettors and manifolds have been fitted and tried.
But for all I know, he may be on the right track as I am out of my experience and skill range here.
............................. yet after completely changing the ignition system ..........................
Not quite. See above.
Thanks for your encouragement.
