I've got a project "in the lab", which is about to go into production... and there's a bit of a snag. Part of the power supply is done with DC-to-DC converters (the little black plastic potted things) to isolate critical parts of the circuitry. To reduce the noise these push back onto the incoming 24V power supply, there's a 100uF low-ESR capacitor across the 24V input, behind a reverse-polarity protection diode.
Total power consumption of this thing is 50mA, plus about 200mA for some motors and stuff which are usually running but can be switched off by the electronics block under command from a PC.
Problem is, there's been a power supply spec change. We've gone from a 24V rail sourced from a "dumb" power supply (a switcher with an output fuse and a crowbar OVP) to an all-singing-all-dancing "smart protected power supply" which does open and short circuit detection. For bonus points, the "smart" PSU has fast-switching outputs - essentially a relay driven from the output filters, via the open/short protection circuit. The dV/dt is essentially as fast as having a lab PSU on and ready, then switching the power to the unit with a mechanical switch, only without the contact bounce. There is no soft-start.
If the device being powered draws more than 400mA for 200us, the PSU will declare the output as shorted and trip. The 100uF capacitor and power supply components (DC-to-DCs) are taking it way over this limit - by the highly scientific method of "stick a 1R resistor in series and measure across it", I'm getting 7A (falling exponentially, but not fast enough) for a couple of hundred microseconds, more than enough to trip the PSU.
I can't make any modifications to the shiny new power supply or its wiring, but I can modify my circuit's power supply all I like within reason. I'm not keen on adding a series resistor to the low-ESR cap as it'd impede the filtering ability of the capacitor, and the voltage drop over a series resistor on the 24V input might cause problems for the DC-DCs (this device could potentially be on a long run of cable and needs to run down to about 20V). An inductor (I've tried up to 100uH)
Can anyone think of a way I could reduce the inrush current enough to get by the limit, without impeding my capacitor's ability to filter the DC rail?
Cheers,
Phil.
