Hi!
I'm having a little trouble calculating a reasonable inductor in a inverting boost topology converter (schematic below).
It is a some sort of bizzare converter topology, but is correctly working. Quite nice solution actualy, if you need to get a +-16V from a lower voltage with two same convertor ICs.
The converter I'm trying to design should be as follows: 12V input, -16V 0.3A output:
By taking the rule of equal voltseconds, ton*Uin = toff*Uout, one can get that for CCM mode the duty cycle s = 1 - Uin/Uout. So the duty cycle required for 16V output should be about 30% (s=0.3)
The switching frequency is 700kHz and current ripple should be selected low enough, due to the core loss at such high frequency. So lets say 10%.
U = L * di/dt can be modified to such form: L = U * dt / di so we can now calculate the inductor. Inductor average current estimated is about 0.55A (17*0.3 = 5W output means about 6W of input at 12V)
L = U * dt / di = 12V * 0.3/700kHz / (0.1*0,55A) = 90uH
What I have a problem with, is that the inductance seems to be too high.
Problem 1: the saturation current of such coil should be at least 0.7A or more to be on the safe side. At 100uH this is not a small inductor, this is a solid chunk of core.
Problem 2: SRF of such coil probably too low, wouldn't that cause trouble at those 700kHz of operation?
Can you please check my calculations and/or suggest what I have done wrong or what should be considered different way? Am I too conservative with the 10% current ripple?
I am used to design quite higher power convertors (up to two orders of magnitude more power), where the switching frequencies are mostly well below 100kHz. I don't usually design those funny small converters with rocket science frequencies. So I'd be very happy to hear your suggestions for this stuff.
PS: Also what inductor type would you recommend using? Is something like this okay for 700kHz?
http://datasheet.octopart.com/B82472G4224M-EPCOS-datasheet-519061.pdf or do I need something completely different?
Thank you,
Y
