As the subject states, I am purposing an old transformer for a general linear power supply, car battery charger, high current, etc... Because I plan to charge automotive batteries with it I need at least 14.8V after rectification and regulation, and yes, I want to regulate it properly, it will be used for other general stuff too.
The transformer came from an old junk UPS and as such has some very beefy secondary windings (well, they were the primaries), and multiple taps on the primary for various voltage standards. The secondaries are 7.6-0-7.6 CT, and the available primaries are 200, 235, 270V. In our area the standard is 230V, but I measure 240V here
. It also has a 17.5V secondary for the control logic, which is what makes this transformer attractive still.
My question is... would it be safe to power the transformer from the 200V input to give a more usable output?
Unfortunately I have no more specifications on the transformer as it is some OEM specific product. I do know though it is happy to push 8-10A across the entire secondary (15.2V) when on the 235V tap.
With my prototype design so far I am able to achieve regulation at 13.5V @ 2A, I am using a MAX6350 (yes, overkill but I have a bunch), a NE5532 opamp, and a TIP112 darlington to drive 3x 2n3050 transistors. I have the series pass transistors and capacitors on the negative side which solved a few issues I have with my other supply for bench use (output filter capacitors taking too long to discharge), and overall better regulation.
