I am reverse engineering a boat navigation light, in order to repair it for a friend. It is a typical LED circuit. All LEDs are 5mm/3.2~3.4v. All Resistors are 1k. The VR is a 78L12. The thing which resembles a diode is the mystery...
I have used a diode icon as a place-holder on the schematic. However, I am not certain what I think the part may truly be... It is the common shape of a black, cylindrical diode, but it has absolutely no markings on it, not even a polarity band. It does measure as polarized and has 2M of resistance.
A diode for upstream electrical protection seems a bit unlikely, as a diode drops a volt. A fuse doesn't fit the criteria, as it would not be polarized.
The PCB has multiple holes for this component, to allow various parts to be sourced, based on pricing. The back of the PCB has SMD pads for it. That is marked M1.
Any ideas what it might be? Thanks for the help!
