Does anyone have any suggestions for switching an isolated DC load other than using a mechanical relay?
If it was AC (or periodic in some way) I'd use a solid state relay.
The DC load is not very great (under 50v, low current).
Right now I'm using an open collector output - but that is sharing a ground and causing other issues (connecting my board via USB to a PC makes a ground loop, etc.).
Thanks!
