Some more info :
The display is a BOE VFD 20-0814F, these are for sale on ebay by several sellers.
They are new old stock, I do have a datasheet but it's not the exact same type (I think), the last letters are different.
When I apply the filament voltage as in the PDF (2.7V AC) the filament glows very visible, that can't be good.
I now have 2V RMS at 100kHz (measured with my scope) and that works fine so far in my test setup.
For the anode voltage I now have about 18V, that just for testing in static mode. When driving it dynamicly I will have to bias the filament voltage to prevent ghosting. This bias voltage will add to the high voltage.
The datasheet shows 31V max. So I need at least 31V + 5V = 36V.
I'm planning to modify a common step-up convertor to go up to about 45 volt. I want all to be powered by 5V DC.
For driving I want to use three HV5812 (or the A6812, that's an obsolete compatible part, can still be found).
The anodes and grids are tied to the outputs of the HV5812's, they are both driven with the same high voltage.
So I shift in all the bits for a specific digit and grid, strobe the latches, wait for some time and do the next digit.
Dimming will be done by PWM on the blanking pin of the HV5812.
That's the theory. Will have to see if it works, waiting for the parts and PCB now.
I also want to write the software to show nice scrolling text, but first concentrate on driving the display.
On the long run I would like to make a sort of remote display for my domotics system,
scrolling some sensor value's, time, date and other information.
b.t.w. I do like these rolling numbers :
