One of the big problems for a power supply is the unknown load.
That's the challenge really :
Designing (not copying or combining a few integrated regulator's) a DECENT bench power supply really takes a fair amount of knowledge and skill, many try but few succeed in creating anything decent, the web is full of them.
It's far more challenging than designing a C.V/C.C source (linear or switcher) for a 'known' fixed load.
No, not at all. In my previous post I explained that I had eliminated instability when C6 is 1uF. I can even get it to be stable with no output capacitor. But I will be putting a 47uF on the output when I finish it.
To be sure a design is up to the job you have to test the stability and frequency response under the most 'unfavorable' loads you can expect.
knowing what the most unfavorable conditions possible to test under then is crucial in a design/test process.
Here's a few suggestions to try :-
For C.V Mode:- test at a set voltage that gives lowest voltage across Mosfet (which gives max Cgd) and near the max current rating of the supply using a current sink as the load (so high Z load) and load the output with ceramics, say 2uF worth to emulate a load which may have lot's of ceramic decoupling cap's (so this test has created the lowest possible frequency gate and load pole's using very low esr caps).
Then also test with just a low ohmic load and no load capacitance and at high current and at max/min voltages (now there is no load pole and a high current (= higher FET Gfs) so the Vcntrl loop should be at max gain/speed).
For CC mode test. Try load stepping at high current with various pure inductive loads (10uH,1mH,100mH), but the large capacitor you generally find on the output of supplies though makes C.C mode very stable and ruins it's transient load response .
The large cap on the output of almost all bench supplies is a bit of a fudge really but it gives a very good load transient response in CV mode and makes for easy stability (rely's on large size and ESR) so the trade off is sacrificing CC mode performance in favor of CV mode performance.
Best Regards . Kevin
