Regarding adjusting the offset of an LF411 using V+, I tried it last night. Nope, it doesn't work. I don't think I would have tried that experiment with a $25 op amp.
The LF411 datasheet is old enough that it includes a full schematic which show the offset null connections which is what I used to verify how they should be used.
I'll spend a bit more time comparing op amps but then settle on my choices. I hate choosing op amps; there are a billion of them and the specs are always incomparable. For the lowest noise and highest bandwidth, I suspect the front end should be discrete anyway.
It takes experience to recognize the different types of operational amplifiers. A JFET input operational amplifier would generally be the best choice for the input because of noise and input bias current but a discrete design has some advantages for input protection, controlling input capacitance, and coupling between the inputs.
The LT1102 JFET instrumentation amplifier is one of the very few suitable parts for the input amplifier but check out its common mode rejection ratio at 50kHz of less than 40dB versus 100dB for the Tektronix AM502. An AMP02 does a little better and would be another good choice for a simple design.
Getting better performance will require using JFET operational amplifiers or discrete JFETs.
I didn't know about the am502. I thought about putting my design in a 500 module, but didn't like idea of roar of the TM500 mainframe and the difficulty of working on that physical format.
I do not know about a "roar" but I would not suggest building a TM500 module either. The 1, 2, and 3 bay TM500 mainframes have no fan.
I like the idea of matching scope probe impedance and optional AC coupling.
The big advantage of being able to use x10 oscilloscope probes is that they provide a lower input capacitance and shielding. The problem is that their mismatch compromises common mode rejection.
With that in mind, I would make the 1 megohm input shunts trimmable so that a pair of standard x10 probes can be used without compromising common mode rejection. The way Tektronix achieved this was to make special adjustable x10 probes.
In what situations is the infinite impedance input useful? Does it occur often enough that the switch should be brought to the front panel? I am trying to avoid feature creep....
The AM502 just has a jumper on the inside. Trying to switch such a high impedance point is difficult to do without adding leakage or coupling.
Don't underestimate the value of those bandwidth filters, as when you apply high gain you'll see nothing useful without them. That also tells you that trying to build a very high bandwidth circuit for high gain applications is probably a waste of time.
The need for bandwidth limiting becomes very apparent when using the 5A22/7A22/AM502 at high gain or high sensitivity with an oscilloscope. Note that these three instruments are all the same but the AM502 is intended for stand alone operation with a separate instrument. An AM502 would have been paired with an
AF501 variable bandpass filter to make spot noise measurements before FFT spectrum analyzers became available.
Noise reduction can also be implemented through the averaging and high resolution functions on a DSO.
