Thank you Benta. What you say is not correct, since varying the capacitance induces a change in voltage and current. Think about a microphone, where the voltage goes up as charge stays the same while the capacitor 'plates' come closer together.
Usually we have C*dV/dt = I,
but in this case we have C(t)*dV/dt = I - V(t)*dC/dt
I am a little confused.
Are you actually pumping a a sine wave signal through?
Laplace will let you solve this equation in a linear fashion (ie with just algebra), but you may be misguided as to what you are trying to do. That being said, you do not need laplace to do it, so doing the whole transform would be a lot of work for nothing. Everything is first order.
But if you want to figure out, google first order equations and Laplace. As Benta pointed (and he is not incorrect), you will need an assumption of the initial condition.
