I am looking for two LARGE sheets of perfboard / Vectorboard / Veroboard. Specification is as follows:
Minimum size 30cm x 30cm usable area, 36cm x 36cm or larger would be better
Square or round pads on one side
Either single sided or (even better) copper groundplane on the other side to the pads
FR4 material, although alternatives will be considered.
I've tried all of the usual distributors such as Mouser, Farnell, Digikey and RS and I have also tried contacting Vero and Vectorboard directly but none of them can help. Unless I can find a source of this large material I may end up joining smaller sheets, an approach which has certain mechanical disadvantages.
Can anyone assist?
