Author Topic: LDO regulators.  (Read 1274 times)
Offline nigelwright7557Topic starter
    • Electronic controls
LDO regulators.
« on: August 09, 2018, 02:58:27 am »
I recently built up a circuit with a PIC32MX220 and a few other analogue components.
The first pcb worked fine.
So  I built up a second one and it didn't work.
The problem turned out to be lots of noise on the 3v3 line.
I looked up the 3v3 ldo regulator spec and I had a 100nf instead of a 2u2 capacitor on the output.
So I swapped it for 10uf.
So  I built up a third one wit h10uf in it and that was noisy too !
It needed a 47uf to get rid of the noise.
These ldo regulators are great with low drop out voltages but can be a bit unstable even if care is taken with pcb layout.
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: LDO regulators.
« Reply #1 on: August 09, 2018, 04:48:35 am »
So what LDO did you end up using, also post your schematic/pcb too ;^)
Offline mzzj
Re: LDO regulators.
« Reply #2 on: August 09, 2018, 06:45:28 am »
Offline CJay
Re: LDO regulators.
« Reply #3 on: August 09, 2018, 11:03:55 am »
Yeah, I found that out too after making the (stupid, I know better) assumption that pin compatible 3 terminal regulators are an easy swap out, it's definitely a good idea to read the datasheets and not assume anything with them so there's a few tubes and a box full of LDO regulators in my W/shop with very clear labels advising me how to use them.
Layout wasn't so critical for me (either that or I did it right without trying) but the bypass and filter caps, most important or the 'regulated' rail was awful.
Offline james_s
Re: LDO regulators.
« Reply #4 on: August 16, 2018, 07:08:30 am »
I ran into a similar problem recently. I was repairing a keyboard for an old serial terminal, didn't take long to figure out that the 7805 was dead. I didn't have any 7805's in my stash but I had some other 5V 3 terminal regulator salvaged from something or other so I installed. that. Keyboard powered up but didn't work properly so I spent hours troubleshooting and testing ICs before I had the sense to scope the 5V line and sure enough, crazy oscillation.
