Author Topic: LED Matrix  (Read 6127 times)
Offline ebastler
Re: LED Matrix
« Reply #25 on: February 18, 2018, 05:49:48 pm »
Hi PixieDust, just read your post about the simulator display and remember this https://www.4dsystems.com.au/product/uLCD_220RD/.
Hmm, interesting. They must have gotten their hands on a batch of diplay meant for watches, I assume?
But these are quite expensive, "not recommended for new designs", and "out of stock" according to their website. I think for the multi-dial display Pixiedust is after, a larger rectangular screen behind an overlay is the simpler and lower-cost option. And the result would look identical, right?
Offline Nauris
Re: LED Matrix
« Reply #26 on: February 18, 2018, 09:01:53 pm »
I think it is possible to build this with 0201 size leds.
I experimented layout with seeed pcb service minimum design rules (3/3 mil and 0.1 mm via) see image.
Only two layer pcb is needed. Assembling it may pose own challenges.
It is likely necessary to in-fill space between leds with some black ink to reduce crosstalk.
« Last Edit: February 18, 2018, 09:09:08 pm by Nauris »
Offline PixieDustTopic starter
Re: LED Matrix
« Reply #27 on: February 19, 2018, 07:47:26 am »
That is a very nice display. I bet it works great with a wide range of ambient lighting, has a great viewing angle, wide operating temperature range, high noise immunity and laughs off any vibration you throw at it. For those reasons I can understand your desire to use an LED matrix - because LEDs just work. Reliably. Always. **
Mechanically more complicated but: maybe you could consider some type of lens to reduce the apparent size of a larger LED matrix, like the stackable Liteon arrays https://www.digikey.co.uk/products/en/optoelectronics/display-modules-led-dot-matrix-and-cluster/96
** OK, some of that depends on driver circuitry too but when using an off the shelf OLED you lose control over that to a large extent.
Edit: Ahh, this is for a simulator, so you have more options.
Yer for a flight simulator I'm not too worried about things like vibration but the viewing angle and good visibility in various lighting conditions is definitely a must. But as I said, the other important reason is to try to fit the thing into it's own boundaries. I don't want displays sticking out past it's perimeter.
EDIT & P.S.: I looked over the available OLED/TFT displays on digikey and none of them were of the right size
There are a lot more display types out there than are stocked by Digikey, so worth looking at other sources in case there is something that may fit.
Gocha, will look into it a bit more.
This is a great display unit. Want one.
These LED matrices are made of naked LED chips placed on horizontal traces and vertically connected by bond wires (like in this 4 digit alphanumeric display). You can still buy these as standard modules (4 or 8 characters 7x5 matrix), but yours is for sure custom made from pure unobtainium.
I've got another idea: in modern car dash boards, they use TFT LCDs masked by "instrument dummys" (so they get round shapes and whatever). If you place a large and brilliant enough TFT screen behind that mask, it'll at least look alike this original display.
This has peaked my interest... very useful thanks! I think I'll need some time to think this over. I'm pretty tempted to see how much a custom made one would cost if custom made is even an option. Unobtanium doesn't sound good, but I'm up to see just how unobtainium it is. I'm trying to figure out how it works though. It's as if each of those LEDs have only 1 terminal? Doesn't make sense to me how they wired it up. They have a strip connecting all the LEDs horizontally and then they also connect each column as well, so it seems like each LED is connected to every other one!
EDIT: I think by naked LED chips you mean each LED is basically not soldered to a PCB?
Hi PixieDust, just read your post about the simulator display and remember this https://www.4dsystems.com.au/product/uLCD_220RD/. I think maybe the YouTube video https://youtu.be/fRhZx4gfyCI has had a bit of post processing though.
Anyway, you said you were looking for square displays and something like the 4D systems uOLED-128-G2 1.5 inch display might come close to your requirements. From a practical point of view however, the display and driver PCB are stuck to the plastic carrier with double sided tape and I never had much luck getting them apart. Display is SSD1351U3, Phoenix Display DLC0150BNOF, and Mouser even have a breakout board 763-NHD1.5128128UGC3.
That's a nifty display. Unforunately, it's a bit too small. I'm starting to realise that square displays or round ones like you suggested won't work. As you can see from the instrument, the bottom of the round dials are cut off, plus, there's 7 segment displays below a few of the rows which would be impossible to have with small square or round OLED/TFT screens.
But overall, thanks, I need to think through this new info and do some searching and researching. Maybe I'll find something that suits.
Yep, if all else fails, this is the route I'll be taking. The only difference between the real thing and my replica will be a ticker plastic to accommodate the potentiometer and the buttons, which will need to sit on top of the screen.
Will be experimenting a bit to see if it's feasable. I have already thought about filling the voids between the LEDs to prevent cross talk as you suggested. Have a few ideas, not sure how expensive some of them are though or how realistic. Needs more thought and research. Thanks for the suggestion.
« Last Edit: February 19, 2018, 08:53:02 am by PixieDust »
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: LED Matrix
« Reply #28 on: February 19, 2018, 09:19:21 am »
Custom TFTs are not an option - MOQs are in the hundreds of thousands and tooling costs many thousands.
A small custom rectangular monochrome matrix LCD which could be backlit might be an option if you have a couple  of K to spend on getting a few hundred of them, but you may not get enough contrast.
I'd be looking at one or more LED pico projectors back-projecting. That is probably going to be the cheapest option for a 1-off build.
TI do a nice little projector eval board that fits a Beaglebone: https://www.mouser.co.uk/ProductDetail/Texas-Instruments/DLPDLCR2000EVM?qs=BZBei1rCqCAQetmBz0G1xQ==
Day Job: Mostly LEDs
Re: LED Matrix
« Reply #29 on: February 19, 2018, 10:08:34 am »
I didn't mean custom TFT, I meant custom LED matrix. I already asked about custom TFTs a few years back, price was :-DD or :scared: as you described.
Re: LED Matrix
« Reply #30 on: February 19, 2018, 10:25:09 am »
In principle you could get a cusom die-bonded LED matrix but you're going to have significant tooling costs. If you're luckky maybe you can find someone who you can send your PCB to who will just do the LED bonding ( and please let us know if you do!).
Withteh advent of SMDs you don't often see die-bonded LEDs these days.
Re: LED Matrix
« Reply #31 on: February 23, 2018, 08:35:38 am »
Will look into this thanks.
Re: LED Matrix
« Reply #32 on: February 25, 2018, 09:22:22 pm »
This might be an option, if you can find a source for the materials
https://hci.cs.uni-saarland.de/files/2014/10/PrintScreen.pdf
This appears to be the source of the materials - no pricing AFAICS.
http://www.gwent.org/gem_electroluminescent_kit.html
Lifetime of a homebrewed solution might be questionable.
« Last Edit: February 25, 2018, 09:31:24 pm by mikeselectricstuff »
