For maximum visibility, (Cool) white, small size, narrow angle if your viewing angle . match angle to required viewing angle. If you want to stand out from other lights, maybe deep green, as this is at the peak or the eye's sensitivity.
Where you want "noticeability" for emergency type applications, strobing can help as the eye is more sensitive to movement.
In principle, for a steady brightness, PWMing doesn't give any advantage in terms of perceived brightness, but efficiency at low currents (< about 5% of nominal current) can vary a lot, particularly with white, so if only for consistent appearance, a higher current pulsed at a low duty cycle can be beneficial.
