I just wanted to share my quick Lithium-Ion battery capacity tester. It's based on an Arduino Mega (although the Uno or pretty much any other MCU could be used), and discharges the battery through a 4-ohm load for approximately 1A of current. I've attached the Arduino sketch as a .txt file as the .ino filetype isn't on the forum whitelist.
Yes, I know it's yet another Arduino project / whatever, but I spent some time on it and the info might be useful to someone in order to save them the effort
I'm testing 18650 batteries which I pulled from old laptop batteries.
EDIT: I didn't bother with a schematic, but the hardware side is as follows: the battery is connected through a 4-ohm 7W load to the N-channel enhancement-mode MOSFET's drain. The source is connected to the battery's negative terminal and to ground. There's a 47k resistor across the gate and source pins and a voltage sense wire coming from the point the battery's wire gets to the breadboard.
