I'm making a battery powered device with a load cell in it. I would like to run it from a CR2032 cell, so not much more than 2V from a nearly empty cell after an LDO drop.
Most load cell datasheets recomend an exitation voltage of 10V and while they specify a maximum voltage, I have not seen any specifications for minimum voltage. As a loadcell is just a Wheatstone bridge, I can't see any reason why it wouldn't work with an arbitrarily low voltage(?)
The full load output voltage will drop linearly with the excitation voltage, so a higher gain amplifier would be required and noise could be more of a problem. Other than that I can't see any real problem with a low excitation voltage. Am I missing something?
