I first thought about a modified ZVS, but I want to avoid it since this is a college project and I have to give it some theorical basis (and there is a lack of it related to Mazzilli drivers, almost like if people are happy enough if it works xD). So here I am looking for any book or website where I can find information about Push-Pull transformers.
Sorry, it seems we ran away from your topic a bit. If you want more detailed info on 'a ZVS,' you would do better to use a real name for it. ZVS = Zero Voltage Switching, which is a
property of a converter, not a specific
type of converter. Try looking for a Royer oscillator/converter. Or a 'self-commutated push-pull converter.' Sadly, much of the power electronics information that's readily available online (especially on Youtube) is woefully incomplete 'suck it and see' work, without any theoretical treatment.
Also, 5kV / 150W = 33mA. That would definitely burn you and could kill you,
especially if there are large capacitors anywhere. And you might find that none of the test gear in the lab is rated for it. If you're actually going to build it, you need to get some safety training, which should be provided by your college.
The output must be AC because there will be a voltage multiplier there.
Ah, so that's why you want AC output from the transformer. So what you
really want is a DC-DC converter consisting of a high frequency transformer stage and a voltage multiplying rectifier. That's extremely relevant. You can't just design 'a transformer' and connect it to 'a voltage multiplier' and expect everything to be fine; you have to design all of the converter at once.
I don't think I will need regulation. The load of the transformer is a voltage multiplier feeding a resistive load.
You need to pin this point down. I'm 99% sure that the 'resistive load' is something more complicated than just a resistor. Typical guesses would be photomultiplier tubes, X-ray tubes, assorted RF power amplifier tubes, LINAC stages, electrostatic precipitators, capacitor bank chargers etc. Pretty much everything in that list will actually need some regulation to give consistent performance, so make sure you're getting a good specification for the project. Remember your 48V supply will have some tolerances too (e.g. if battery powered you're looking at a range of 40 - 55V). You may have to quietly determine who is designing the equipment that connects to your converter and sidle up to their desk informally.
If space is critical, you'll need to keep an eye on the following:
- Choosing the right switching frequency
- Using a symmetrical topology which applies both positive and negative flux to the transformer and transfers power to the output on the positive and negative cycles
- How much creepage clearance you will need on the transformer secondary winding (hint: LOTS)
- Getting as much primary voltage as possible to reduce the turns ratio (so use a full-bridge inverter).
Based on these criteria, I think that a classic H Bridge, Phase Shifted Full Bridge, Series Resonant Converter, Parallel Resonant Converter or LLC (with full bridge driver) might be a good start.
When you design the transformer, you'll see that the creepage & clearance requirements are critical. In addition to the primary-secondary insulation, even the end-to-end insulation of the secondary will be critical too. You may well end up using a sectioned winding approach. This takes extra space and adds significant leakage inductance. Benta is right that ETD59s are not an ideal geometry for this situation.
5 kV - really? In that case, the ETD59 is not a good choice. I'd say a U-U core with separate primary and stacked secondary would be more appropriate.
Given these conditions, an LLC with an H-bridge primary side driver might be a good option. Here are the qualities that could help:
- Uses transformer core symmetrically - improves density.
- Actually uses transformer leakage inductance.
- Generally doesn't need snubbers.
- Can provide voltage gain and regulation by frequency modulation, in addition to the transformer turns ratio.
- Achieves soft switching of primary switches (subject to constraints on load and operating frequency). Good for EMI and efficiency.
- Achieves soft switching of secondary diodes (subject to constraints on operating frequency). This is really useful because your output multiplayer will have lots of diodes in it.
The downsides:
- Usually controlled by varying the switching frequency.
- Likely to experience hard switching during initial charge of all the capacitors on the rectifier side.
- Efficiency isn't fantastic at light load (but improvements are available).
