Basically, I'm looking for where I may likely salvage an 8V, 10A DC supply (I'm cheap).
I am planning to use a brushed 540 sized RC car motor in a Dremel kind of application. It will be used to drive a small rotary cutting tool through a 1:1 metal gear. I have a decent variety of RC motors from which to choose, "stock" 27 turn to 11 turn performance motors. The load on the cutting tool will generally be light as they are small tools, about 1/8" (3 mm) or less. I do want at least 10k RPM.
The stock motors run fine with my 5V bench supply, but could use a bit more voltage. The performance motors don't quite spin up with 5V. Most of these motors will overheat with a typical 12V supply.
I'm planning a direct connect, no speed control.
