Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
MOSFET over heating at lower than expected load currents
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: MOSFET over heating at lower than expected load currents (Read 872 times)
ReadyEdi
Newbie
Country:
on:
December 10, 2017, 01:48:20 pm »
Hello there,
I'm testing a new switch method for my battery cut off circuit and when testing the FQP27P06
https://www.sparkfun.com/datasheets/Components/General/FQP27P06.pdf
P channel mosfet at 12V at the source and 0V at the input it generates quite alot of heat without a heat sink at 5A and when measuring the Vds voltage and multi pling it by the current I get around 2.15Ohm which is way above what is being said in the datasheet.
Why is that?
Thanks for helping
Logged
danadak
Super Contributor
Country:
Reactor Operator SSN-583, Retired EE
Re: MOSFET over heating at lower than expected load currents
Reply #1 on:
December 10, 2017, 02:13:28 pm »
At Vgs = 12 V you are getting somewhere around .07 Rdson,
so P = 5
2
x .07 = ~ 1.75 W, so part w/o a heat sink
would be quite hot, burn your pinkie.
Tj-c is ~ 62 C/W, so case would fry eggs.
Regards, Dana.
Logged
ReadyEdi
Newbie
Country:
Reply #2 on:
December 10, 2017, 08:25:12 pm »
Hi thanks for the replay regarging that do you maybe know of any other better component to suit that need that doesn't require a heat sink for long continues operations?
Logged
Freelander
Regular Contributor
Country:
Reply #3 on:
December 10, 2017, 08:43:31 pm »
You can get lower RDSon devices but it is not too bad to start with. I presume this is fully on ? - not pwm'd etc ?, so not operating in the linear region at all. If the gate is at 0v and the source at 12v then you will have the device fully on.
You can put multiple devices in parallel, it is a method we have used in various devices many times. Worth putting a low value gate resistor for each fet - 100r 'ish. that will work fine.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
