I need to run a small (<150W) three-phase motor at higher adjustable speed than the 1400 rpm @50Hz. As luck would have it, I have found a pcb seemingly ideal for this. I do not know what it was meant for originally.
Other than the mains input and motor connections, there is only just a four pin socket (header), with markings as in pic.The external circuitry to be connected is entirely isolated by the two opto's, needing only logic level (5V). One opto has its LED input at the header pins, and is wired to the pin marked '5V' through a resistor, with the cathode left open at the third pin. The other opto is assembled with its LED input on the live micro controller side, and just the transistor output at the remaining two pins of the header. The markings are 'RPM' and 'FB' respectively. I would have thought FB is for feedback, and cannot be the output of an opto.
I have removed the heatsink to see markings on the power chip, there are none. The microcontroller is also undecodable. The IGBT bridge should be several amps at least. The power input is wired for 230V single phase.
Connecting a dc 5V supply ANYWAYS does not enable operation.
What is wrong?
