Ian.M It comes down to your local regulations somewhat, for Australia if the device lacks a return to home function, or position hold. it its intended to fall out of the sky on signal loss rather than continue in whatever direction its flying in, the assumption being that a small drone with stopped propellers is generally less dangerous than one flying forward at what could be maximum speed.
For the DJI crowd, gps is baked in, and the hold or return options are met, for the racing group, a GPS reciever is weight that is generally ditched, with the controlled drop being preferred. not a landing, but a drop, if a propeller is partially damaged the drone can shoot off in 1 direction while trying to reach level without ever quite reaching it. leaving a motor kill / stall the only reliably safe option
And finally, racing drones due to there light weight mostly bounce on grassy areas undamaged, even on concrete you would rarely break a frame, maybe bend a motor and break some props, but you carry spares. I can say my own crash counter is in excess of 150+ on a 1.3kg drone some from almost 60m up, and have yet to break a frame of the core electronics, many props damaged, but still quickly repairable, the only crash i struggled to walk away from was top speed into a light pole (~135kmph). that bent a motor, trashed a camera, and broke a number of screws.
