Author Topic: LTSpice design  (Read 6067 times)
Offline J4e8a16nTopic starter
    • Jean Pierre Daviau
LTSpice design
« on: April 14, 2014, 02:32:06 pm »
How can I create a back EMF simulation of a motor in LTSpice?
It is a 1.5 volt  toy motor.
Rename the file to  BackEMF.asc  to use it
JP
Equipment Fluke, PSup..5-30V 3.4A, Owon SDS7102, Victor SGenerator,
Isn't this suppose to be a technical and exact science?
Offline dannyf
Re: LTSpice design
« Reply #1 on: April 15, 2014, 06:04:23 am »
Yes, if you can articulate the mechanism of back emf.
Re: LTSpice design
« Reply #2 on: April 15, 2014, 03:05:45 pm »
Here is a trial.
Re: LTSpice design
« Reply #3 on: April 15, 2014, 03:07:10 pm »
Here is the asc file
Offline codeboy2k
Re: LTSpice design
« Reply #4 on: April 19, 2014, 12:31:00 pm »
I have the following lying about, I found it online a while back from the University of Colorado Electrical Engineering course ECEN2830.  You might find it useful to you.
There are two .asc files in the zip file  (1) DC_motor_model.asc and (2) DC_motor_model_test.asc
The motor model includes the back emf and the current changes as the load changes. There is an input that you can use to control the load.. The test file uses a PWL current sink at the load control input (omega) to apply varying loads.  The test file applies the voltage step to turn on the motor, and then turns it off, at which point you can see the current draw and the back EMF at the motor's +DC input terminal.  The model accurately depicts the current changes due to load changes as well.
There is also a PWM motor speed encoder output.
« Last Edit: April 20, 2014, 03:28:13 am by codeboy2k »
Re: LTSpice design
« Reply #5 on: April 19, 2014, 04:11:24 pm »
Thank you so much.
JP
