I want to build LVDT. Seems easy but what ratio. Should i use between core thickness, coil lenght and travel?
I.e. the LVDT sensor is 3 inches long, with one inch per coil.
How long should the magnetic device which travels should be? 3 inches? Slightly larger?
Also, how do i set the limits before nonlinearity due to leakage inductance sets in? I.e. for a three inch coil, whats the recommended displacement?
I.e. if the displacement is 0.8 inches, this leaves 20% of the original core lenght in the top inductor. Does anyone know the percentage of core required where displaced vs the nonlinearity incurred? (i want to know when i can avoid look up table
I assume it will lead to weird coupling if displaced too far.
I wanted to use 100KHz
Also the middle can be thinner right? So long the end bits are symetrical.
