Firstly, apologies if this has already been asked.
I understand the dangers of electricity, etc, I am not 17th edition, but have a G39 certificate allowing me to wire things up on the side of the road without supervision.
Now the safety disclaimer is out of the way
I have seen several designs for home automation, one that springs to mind is the Itead smart switch (1,2 or 3 channel), which goes in place of an existing light switch and has a soft switch on the front and a 433MHz RF link inside.
I am guessing that this is either logic or micro controlled, thus needing 3.3 or 5V DC power, the RF receivers are typically 5 or 12V and I guess they are using a relay to switch the contacts.
My question is, bearing in mind how small these switches are, how on earth (no pun intended) do they get DC from a single AC hot (live) wire without using some monstrosity of electronics? I guess rectification must come into play, and maybe some kind of transformer? Albeit a small one or perhaps not isolated at all, but how they they do it without a neutral wire?
Light switches generally work on the principal that you have a constant live and a switched live (which goes to the lamp live) and Neutral is already connected at light source, I could understand if the light switch was earthed as that can act as a return, or if the light was switched on, there is a path to Neutral through the lamp, but when the lamp is switched off, or the relay is open, I can't seem to figure out how they (and other companies) did it.
Any shedding of light greatly appreciated!
