So how do you "ensure polarity" if your country uses symmetrical plugs and indeterminate wiring standards?
You do not. You make sure for instance that with a mains switch inside equipment you always switch both connections to the mains.
No, you don't. There's actually no reason to.
Even in our country (netherlands that is) the utilityboard (entrance of electricity to the house) with it's automatic fuses and GFCI's have to switch both poles, so also neutral.
That has no relevance to switching in an appliance.
Some often used appliances do offer the possibility of contact with exposed Mains .
My daughter received a shock from a Toaster,which had three bad design features.
(1) The element reached up too close to the top of the bread slot.
(2) When it was not in use,but still plugged in,one side of the Mains was still connected to the element.
(3)The power lead was wired with the Active & Neutral inverted.
(In Australia,you can't reverse the plug in the socket,& pin allocation at the power socket is mandated by law)
All would still have been well if the internal switch which opens when the toast pops up had been DPST,instead of SPST,which would have eliminated (2)
In this case,the switch only opened the Neutral line,so no matter how the element was wired,the shock hazard remained.
By the way,she didn't stick a fork into the Toaster,she just reached over the top off it & obviously part of her arm just touched the element (1).
She has a little "El Cheapo" Toaster,but bought this new one because it could toast bigger slices.
On testing,I found that the cheap one did have a DPST switch,so it was put back into service.
