The German computer magazine c't did a report on that (
https://www.heise.de/ct/ausgabe/2015-7-Wie-Profis-Super-8-Filme-digitalisieren-2562344.html - you have to pay to see the full article). Apparently the best/correct way of doing that is to hack a Super8 projector:
1) using the PC or similar to have it advance slide by slide
2) sync that with a DSLR camera with remote control, attached on the projector image outlet (don't know the name)
3) replace the original lamp with a better/suitable one (can't remember which type they used, but I can look it up, if you are interested)
3) capture each slide as an individual slide
4) at the end convert it into a 24 fps movie with compression
The process is preceeded by a professional cleaning of the film. This is a really important step, as most films have collected a lot of dust and hairs/strings.
I have converted around 10 films myself half a year ago. I went the easy lane and just projected the film onto a white screen and filmed it with a mini DV camera. The results are really bad:
1) I did not clean the film, so a lot of dust, particles and fine hairs/strings collected on the corners of the image
2) The mini DV camera is filming 25 fps, but projector is rendering 24 fps - this is not nice
3) Picture is not really sharp and during play the projector actually defocusses slightly
4) Picture does not fully fill the mini DV space (4:3 rendered in 16:9)
5) The mini DV camera will capture surrounding sound (the Super8 films are mute)
Still, it is better than nothing: in my case it was old family films of me as a kid and my parents, which sadly have both died. I wanted to have it stored digitally, no matter what quality, before the equipment and/or the films would fail.
In future I will probably try again in order to get much improved results. However, there is a cost involved: a spare projector to hack, a suitable camera, new light source, controller (Arduino, Raspberry Pi, etc.), time. Probably it is cheaper to just send the films in for professional digitalisation.
Advise:
- TEST YOUR PROJECTOR/PLAYBACK DEVICE ON A SPARE FILM FIRST!!!
- Practice how to playback Super8 films on a spare film
- Purchase some cheap vintage Super8 film on eBay to do these tests
- Consider a professional conversion, but send films one by one, to make sure you don't lose them all in one go
Good luck!
Regards,
Vitor
