Hey guys. I'm trying to get some moulded plastic/rubber DE-9 connectors, similar to the ones on the Sega Genesis:
I can only find the metal version, which has the ears:
But these won't fit in the Sega. What I need is a short cable that has the molded DE-9 connector on one end, and a strain relief bit and a PCB connector on the other end.
So, I need some advice on finding a manufacturer for something like this. I only need about 50, for the first batch. I also need to manufacture the plastic case and the PCB for the other end.
What do I look for? What are the keywords? How do I select a manufacturer?
Thanks.
