Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Measuring 4-20 mA current loop
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Measuring 4-20 mA current loop (Read 1051 times)
Saull
Contributor
Country:
on:
January 18, 2018, 07:18:39 pm »
Hello,
On Danfoss VFD I have one analog output (4-20mA) which outputs VFD frequency. I would like to measure this output with multi meters mA range, do I need any resistor between multi meter and VFD output terminals or I can probe directly ?
Logged
Wimberleytech
Super Contributor
Country:
Re: Measuring 4-20 mA current loop
Reply #1 on:
January 18, 2018, 07:45:27 pm »
Probe directly
Logged
LaserSteve
Super Contributor
Country:
Reply #2 on:
January 18, 2018, 08:14:04 pm »
If it has output short detection, probe with 150 or 270 Ohm resistor in series with meter. Otherwise probe directly.
Steve
Logged
"What the devil kind of Engineer are thou, that canst not slay a hedgehog with your naked arse?"
IanB
Super Contributor
Country:
Reply #3 on:
January 18, 2018, 08:52:08 pm »
Some multimeters have a 4-20 mA mode and will indicate % of scale directly.
Logged
bitbanger
Regular Contributor
Reply #4 on:
January 19, 2018, 04:01:59 am »
To add to what Steve said: the VFD should specify a maximum output load for the 4-20mA output (typ around 600ohms), so any series resistor below this spec will be fine.
That said I personally have not encountered a Danfoss with short circuit monitoring on 0-20/4-20 out.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
