I kinda fail to find a data sheet for 12MHz SMD crystal oscillators by MEC labeled AH1BV and AH1DV.
They look like the S series, except for the marking:
http://www.mecquartz.com/image/download/smd49s.pdfThe label on the first part is
"12.000 G
MEC AH1BV"
And the 2nd one is the same but with "MEC AH1
DV" in the 2nd line.
Any hint where I can find a datasheet for this or if the specs are somehow coded into the characters?
I'd be especially interested in frequency stability (PPM).
