How about a small switch (or reed relay) and a relay or contactor? Maybe a mosfet, depends on your safety demands.
Once the switch enables the coil or gate, the relay or fet does not turn off until the battery is removed.
If you're running from huge SLA batteries you sure can spare a few milliamps for a relay. Mosfets use nothing. But beware of voltage spikes!
*Are you allowed to ship including batteries?
Yes, dont ask me why or how, I do not manage that process. But, are all battery chemistry banned from being shipped? or only Li Ion?
@sacherjj, @Mancave I guess your suggestion and ManCave suggestion are very similar. I like a lot that it is PCB mounted and it seems that they are designed for that purpose. Very interesting one, I would have to deal only with thinking about manufacturing and placing the pull tab (+string if needed) and a space in the case for it to be taken out. The problem that sacherjj mentions is very important I guess: corrosion. I have seen this types of contacts (but I could not come up with the idea
) placed near batteries and oxide starts building on them. Our service life must be >7 years and the unit is exposed to somewhat harsh environment conditions that can promote corrosion.
@AJB thats a great idea, and really ONE time switch. I would need the lowest rating fuse possible. I was looking at this low rating fuse
http://gt.mouser.com/ProductDetail/AVX/F0402G0R05FNTR/?qs=sGAEpiMZZMtxU2g%2f1juGqemH8VKR32Dc1C6vRYh%252b9uc%3d, the datasheet says 50mA but I guess it would require some testing and statistical results. The other thing, and its funny how everything seems to work against us, is that we are using a flexible keypad (no documentation btw
) and I would guess that the keys cannot handle higher currents. I would actually doubt it can handle 50mA. The other thing is that their cost is $0.84 and the lowest cost one (at least in mouser) is $0.16 in unit and $0.125 in 1000s, but its rated at 3.5A hahaha
@kolbep, thats also a neat solution and something we have thought about before. The thing is that, as you might understand, end users are really intelligent and creative when trying to hack stuff. That has been our experience. This switch can be pressed again by the user with a stick. Of course we could cover the hole or fill it with something. Anyways its cheap, reliable.
@Niklas, thats a solution that we can partially implement. Some of the electronics inside are not and will not be designed in house, so we have no control on their IDLE state consumption. We can only connect them or disconnect them through a MOSFET for example. This can help, but we have not control over the complete kit.
Another detail is that we are using a wide range of batteries: from 12V 7Ah up to 12V 100Ah. For the smaller ones, we for sure want to save every milliamp, given our storage time.
I will actually buy some components to try out suggestions.
It seemed at first that this "easy" problem would be "easy" to solve...
