I've been using microwave turntable motors to drive art projects for years because they are strong, and easy to find on the curb. I know that synchronous motors are locked to the frequency of the AC mains and that old clocks were very accurate due to the keepers of the grid making certain they let the right number of cycles escape from the generators each day. I've been told this isn't as important as it was in the past, but due to interconnections in the grid, it would seem that it must still be very important for the entire country to be pretty close in sync. So I planned to make a clock from the microwave turntable motor. I knew they often started in the wrong direction, but once started they continue to run the same direction, so no matter. I tested one while working out the gear ratios and found that while the label says 60Hz, 3RPM, it is actually 2.9637 RPM, making it difficult to design gears for a clock. These are clearly synchronous motors. They run close to the labelled speed, but why wouldn't they gear them to meet the stated RPM? It is only a mater of the right gear ratios. Mine is marked 50Hz 2.5RPM, 60Hz 3RPM. I've tested about 6 microwave ovens. Put a piece of tape on the turntable, cup of water for load, then get your stopwatch out and count the revs/minute. None seem to run at the stated RPM. It is difficult to have a unique idea not discussed on the internet, but no search engine seems to address the issue of why these motors
seem to run slow. Very curious here.
