29/17 is not recommended for use above 200VDC peak, because of creepage in the connector backshell. If you can use a version with a lot fewer pins, and preferably use a separate 3 pin version in a 14 backshell, which has larger pins and bigger separation. Yes you can have 400VDC ( or 250VAC) between pins at STP, but not over the full environmental range of the connector. In high altitude, high humidity or high vibration you can get flashover or leakage between the pins or the shell.
You will also want to have the plug side ( or whatever is going to be exposed to the elements) be potted, which does make the cable rather non repairable, as you will have to fill the rear with a flexible potting compound, after crimping the socket pins and mounting them, and the same for the backshell inside the enclosure.
