Think a bit before asking.
The RC on VCC pin is not "RC" as you probably think. The C is the supply decoupling. The R from the top provides probably startup curent for the IC.
The VCC exact value doesn't matter. The constant current output is met bcs the primary current is known, so is the secondary one.
By controlling primary peak current*, secondary peak current is set. The secondary filter cap makes it filtered, DC average out of the secondary waveform.
*the primary current looks liek a ramp. The IC switches on, current rises (determined by i(t) = 1/L*
integral of u(t)
dt) and after reaching a specific level, the switch is off, energy starts to transfer to the secondary. The secondary current then looks like similar ramp, but inverted. Starts at high current, decreases to zero (as the magnetick energy in the core discharges). Then the whole cycle starts again.
Sorry, this is only very unaccurate description of the basic working of a flyback converter. Use your favourite search tool to get more info on flyback converters. But beware, some complex math can follow.
